Configures the Fabric Attach management VLAN propagation on a specific port.
| management-vlan | Specifies setting he VLAN advertised to Fabric Attach clients for them to use as the management VLAN. (Default is none.) |
| ports | Specifies the port to configure. |
| port_list | Specifies a list of ports to configure. |
| all | Specifies configuring all ports in the system. |
| forward | Configures whether Fabric Attach proxy switches send Management VLAN data to clients. |
| on | Fabric Attach proxy switches send Management VLAN data to clients (default). |
| off | Fabric Attach proxy switches do not send Management VLAN data to clients. |
All ports are configured to propagate the management VLAN.
When disabled, the port will not send out the management VLAN information in the element TLV Support.
This command is only used when operating as a Fabric Attach server. It has no effect when operating as a client or proxy.
The following example disables Fabric Attach port 25 from sending Management VLAN data to clients.
# configure fabric attach management-vlan port 25 forward off
This command was first available in ExtremeXOS 31.3.
